case model SO starter dragging
schramm
07-21-2005 16:12:07
Hi I'm trying to start this SO tractor but it won't spin fast enough.
I was wondering if there was a way to disengage the belt pulley,because I believe this is putting a heavy strain on the starter and not allowing it to spin fast enough.
Thanks for your help...
C. Amick
07-23-2005 14:19:17
 Re: case model SO starter dragging in reply to schramm, 07-21-2005 16:12:07
No way to disengage the pulley that I know of. If it is 6 volt, are you using at least No. 2 size battery cables? Some people use No. 1. Might take a look at the teeth on the ring gear to see if they are bad.
schramm
07-24-2005 03:04:25
 Re: case model SO starter dragging in reply to C. Amick, 07-23-2005 14:19:17
Hi C.Amick,thanks for the reply. The teeth on the ring gear are good and when it is turned over with the spark plugs removed it spins just fine,but with the plugs in place it sometimes won't do more than 1 rev of the crank,but if the mag is in the right spot at that time it will start.
I'm not sure if it is a 6 or 12 volt starter but I am using a 12 volt battery,which I believe would make it spin faster if it was a 6 volt starter.And the cables are what were on the tractor when I got it but I do not know there size.
If the belt pulley can not be disengaged,would the engine stall if you pulled back hard on the clutch lever?
Thanks for your help...schramm...
