Roosa Injector Pump Question
hubbcase530
07-21-2005 06:46:03
My trusty case 530 Diesel was idling and just stopped. I cracked the lines going to the injectors and there is no fuel coming out. I made sure that there is fuel going into the injector pump. I took off the pump timing window cover to see if the shaft was turning the pump and fuel came out. How do I tell if the pump is turning? Should fuel pour out when I remove the timing cover. Anyone have a suggestion on how to troubleshoot this lack of fuel pressure? Any help appreciated!
Tom (Ks)
07-21-2005 17:27:28
 Re: Roosa Injector Pump Question in reply to hubbcase530, 07-21-2005 06:46:03
Fuel will come out when the cover is removed. You can shut off the fuel and with the cover off, remove the timing cap on the lower right side of the torque tube (clutch housing) and roll the enging up to the timing mark of 8 BTDC and check if you can see two lines in the window. If you can't, turn the enging over one more time and check again. If you have someone turning the engine over for you, you should be able to see it turn.
Phil (NJ, AZ, Sask)
07-22-2005 18:51:48
 Re: Roosa Injector Pump Question in reply to Tom (Ks), 07-21-2005 17:27:28
If the pump does not turn you may have sheared the Half Moon Key on the shaft gear. That would suggest that the pump needs re-building as it seized. The hardest part of replacing the drive Key is getting the lower Rad hose back on, without removing the rad Good Luck,
