VAI starter
jdman(MO)
07-20-2005 19:47:55
Had a starter lockup on a VAI. I reasoned that removing the starter would free up the engine. Found I could not remove the starter because the spring was wider than the gap between the flywheel and housing. A local mech. finally got the 2 bolts out that secure the spring and got it out. Now I check the flywheel gap and find that it is about .125 less than my VAC. Tried installing a know good VAC starter and would not go in. Need to find a smaller dia. spring or a smaller flywheel. Anyone else run into this problem? Russ
mj
07-21-2005 13:46:36
 Re: VAI starter in reply to jdman(MO), 07-20-2005 19:47:55
We are all missing something here..... I'll be 'turning it over in my mind'..... gotta be something ''strange'..... Roger????
jdman(MO)
07-21-2005 15:08:42
 Re: VAI starter in reply to mj, 07-21-2005 13:46:36
I am thinking maybe the starter ring is oversize. I have no history on this tractor, and the parts books shows no difference in the starter ring and starter. The only way now to install the starter now is to split the tractor, remove the flywheel, install the starter and reinstall the flywheel. This is no good. Russ
Joe (Wa)
07-21-2005 16:16:41
 Re: VAI starter in reply to jdman(MO), 07-21-2005 15:08:42
Seems like if the ring gear were changed to larger dia the starter gear would have to be changed to smaller dia to mesh. There isn't enough slop in the starter mounting to make up for that is there?
Way out in left field but could the crank have dropped that much?
Joe
jdman(MO)
07-21-2005 20:10:27
 Re: VAI starter in reply to Joe (Wa), 07-21-2005 16:16:41
I have found the problem..there is a boss of about .150 on the housing. I checked 2 other VAC torque tubes and they do not have the boss. Somewhere there must be a different starter drive that is smaller than the 2 I have. The starter drive was rebuilt today with a spring that was.050 smaller but that is not enough. Tommorrow I intend to take a die grinder and remove some of the boss to allow the starter to go in. Russ
