teflon tape
garycase
07-20-2005 13:44:26
can you use teflon tape on hydraulic lines? thanx in advance gary
DKase
07-21-2005 12:59:43
 Re: teflon tape in reply to garycase, 07-20-2005 13:44:26
Don't use the crap! If you get a little to much wrapped on it can crack castings such as motors, valves, and flow controls if you tighten them a little to tight. Go to your local plumbing store and get a bottle of liquid teflon thread sealer. Bottle will last for years, and you don't have to worry about pieces of tape in the system. DK
Joe (Wa)
07-20-2005 19:30:47
The main problem with teflon tape is if you have to remove the fitting again, getting all the tape particles out of the female threads isn't always possible, then when you thread in another male the tape particles get pushed into the system. Very bad for small clearances like spool valves.
I prefer LeakLock for all threaded joints that need a sealant. It is used widely in refrigeration systems, can't get much leakyer (is that a word??)than that.
Joe
petetx
07-20-2005 15:23:32
just make sure to wrap 1 thd.back of the starting thd. so you don"t get any in the system in other word don"t overlap.
JGarner
07-20-2005 14:32:15
Teflon tape is OK to use on all tapered (NPT) threads, just make sure you get the joint good and tight because it makes the threads more prone to back off if not properly tightned.
Do not use the tape on the straight threads on ferrule or compression fittings as it doesn't do anything except make the connection back off easier due to vibration.
Do not use Teflon tape on LP gas line connections, use thread dope made for this purpose.
