Temp Gauge question
dahoude
07-19-2005 16:29:12
I was wondering if anyone could tell me where the wire from the temp gauge connects to on a 1949 Case SC? My gauge does not work on the tractor I just bought a few weeks ago, and I can see why, the wire has been cut off at the back side of the gauge and goes nowhere. Also, the ammeter does not work either, same question applies, how do you hook it up? My oil pressure gauge is working, registers 22 psi when it's at idle. Thanks for any help.
Regards;
Dan
Crispin
07-20-2005 13:15:32
 Re: Temp Gauge question in reply to dahoude, 07-19-2005 16:29:12
I got my gauges from Fleetpride (607)775-0555 NY) but wished I had got the ones that said CASE on them. They're still available but I'm not sure where... I think it was a supplier on this site.
Bob KY
07-20-2005 09:39:42
Aftermarket automotive gauges will work just fine if you decide to replace both of them
Sam3
07-20-2005 07:19:48
The Ampmeter is wired in series in the charge lead between the Generator/Alternator and the battery.
Glenn F.
07-20-2005 06:18:04
The temp guage hooks up to the elbow near the water pump. It is not an electric guage with a sending unit. It is a "mechanical" guage that runs a tube from the guage and screws into the elbow. They are frequently twisted off. If you look you will find the twisted off end screwed into that elbow. Glenn F.
