RC Case engine
Glen Wright
07-19-2005 11:51:54
I have a over steer RC Case that the engine is stuck on and I mean bad. My question is I have the chance to get a Waukesha engine that is. Model FC 118 sn # 471891 can some of you Case men tell me if this engine will exchange with the original engine. Glen
Glen Wright
07-20-2005 18:43:38
 Re: RC Case engine in reply to Glen Wright, 07-19-2005 11:51:54
I guess what I also need to know will other models of waukesha engines interchange with the original one used on the RC. The one on my RC is a FC44F
JHH
07-20-2005 18:36:19
When swaping engines from another application remember that the RC has a wet clutch and the crankshaft is drilled to let oil into he clutch housing also the plug must be taken out of the hole to let it drain back into the crankcase
Arthur
07-20-2005 03:46:37
I've got a 1940 RC at home . I can check the model # for you when I get there tonite. That Weakesha motor was used in alot of other apps. I have a spare motor that came off of an old generator.As lonl as it's the same model# it should swap out allright
Glen Wright
07-20-2005 04:49:02
 Re: RC Case engine in reply to Arthur, 07-20-2005 03:46:37
Thanks, I"ll be loking for your reply.
