Frankenstein's Running!
Glenn FitzGeral
07-19-2005 05:36:55
After more hours than I care to tell Frankenstein's running ('53 DC). I simply could not get it timed correctly. The fellow at the engine shop who put it together was absolutely confident they had installed the timing chain correctly. Not so! I had to remove the magneto drive and back it up 3-4 teeth. It purrs like a kitten now. I guess I don't need the lightning now but we sure still need the rain! Glenn F.
Camboted
07-19-2005 16:42:41
 Re: Frankenstein's Running! in reply to Glenn FitzGerald, 07-19-2005 05:36:55
Congratulations Glenn! Don't be too hard on the engine guy. I have a feeling he put the gears (The DC didn't use a chain) back correctly (the gears are pretty well marked) or your valves would be so out of time you'd either not be able to start it, or you wouldn't have any power. I thought the same thing once, and after pulling off the front end, crankshaft pulley (that's a sweetheart!), and timeing cover, found out I was wrong. Could it have been the mag?? My guess is that, at some point, the mag was put together improperly. I've pulled apart about 6 DC mags and more than one had a timeing problem
Glenn F.
07-20-2005 06:21:59
 Re: Frankenstein's Running! in reply to Camboted, 07-19-2005 16:42:41
I appreciate your giving the engine guy the benefit of the doubt, but anyone will have a hard time convincing me my timing gears are installed correctly. In my desperation I put my SC mag on the DC with identical results. Glenn F.
Camboted
07-20-2005 15:13:08
 Re: Frankenstein's Running! in reply to Glenn F., 07-20-2005 06:21:59
Glenn, I don't doubt your wisdom on this, about all I can figure is that he's off on the top gear only. If he was off on the bottom gear it would affect the way it runs. It sounds like yours runs good. But, if he just missed on the governor gear you could successfully compensate with a mag adjustment. that must be what happened. Hey, "if it ain't broke, don't fix it"
