Sprung A Leak
tom
10-10-1999 18:22:40
I have a 1030 Case. Just got through putting head gaskets on, had heads checked and I am still getting antifreeze in the oil even when it is not running. Does anyone have any idea what the problem could be?
Elmer
10-10-1999 19:54:45
 Re: Sprung A Leak in reply to tom, 10-10-1999 18:22:40
Sleeve seals on the bottom bores are probably leaking. Remove the oil pan and look at the bottom of the sleeves.
Chris Vangel
10-10-1999 18:33:39
I'm not familiar with the model but here is an idea. Does this engine have wet cylinder sleeves? If the seal at either end of the sleeve were to fail it could leak as you said, even if not running. The only place I can think of a static (non-pressurized) leak getting into the oil is from these seals or a good crack in the block if your sure your heads are good and gaskets have sealed. Hope it helps, but it sounds scary, good luck, Chris.
Jim
10-14-1999 19:35:01
 Re: Re: Sprung A Leak in reply to Chris Vangel, 10-10-1999 18:33:39
I agree with these other opinions,, remove the oil
and the oil pan and pressurize the cooling system.
Then it should be easy to find the internal leak.
Good luck,,jsl
