SC Radiator Cap..
Stan(PA)
07-18-2005 10:00:39
It seems like aftermarket radiator caps don"t exist for Case SC. Where do you guys find parts?
Bob KY
07-20-2005 09:05:01
 Re: SC Radiator Cap.. in reply to Stan(PA), 07-18-2005 10:00:39
Here's the cheap fix- Cut a 4 inch wide strip out of an old inner tube about 2-3 feet long and roll this strip up like a scroll. Stuff it in the top of the radiator so that it fits snugly (unroll it and trim if its too fat to fit). Don't worry about it going down in the radiator too far- there is a brace inside that will keep it from dropping down into the upper tank (double check that your radiator has this brace before you try it). This has worked well on our 43 SC for the last 20 years because these cooling systems are not pressurized. An added bonus is that you can quickly see when its about to boil over and slow down the work accordingly. If you leave the tractor outside a lot in the rain you might need to check for antifreeze dilution before each winter.
Arthur
07-19-2005 06:03:55
I think there's one on ebay right now....
dctom
07-18-2005 11:17:53
call 319-523-2805 he may have some left tom
