LP HELP!!!!!
900 DAVE
07-18-2005 05:01:51
Went to my first pull with my 900 lp sunday and did bad when I put the clutch she just bogged down and the RPMs never picked back up Iwas 10 or 12 feet from 90% of the other tractors in my class.any tips guys ? oh what propane valves do I use vaper liquid or both. thanks Dave
big jt
07-18-2005 22:30:52
 Re: LP HELP!!!!! in reply to 900 DAVE, 07-18-2005 05:01:51
All the manuals and LP sumplements I have seen say run on liquid unless the convertor is giving problems frosting over. Ensign R's will frost near the fuel inlet anyway.
Even have a Cockshutt 40 LP that doesn't even have a vapor withdrawel valve.
LP's will run on vapor until you tie into a long heavy pull and then the tank won't have the surface area to boil off enough fuel. Don't know how far 90% put you down the track but a tractor pull shouldn't give a long enough pull to give problems. One exception is if your tank was nearing empty which would reduce the surface area of the fuel.
JM2CW
jt
mike's600
07-18-2005 15:50:43
What gear were you in while pulling the tractor?What weight class were to pulling?
Sounds like you were 2nd .
900 DAVE
07-19-2005 04:36:34
 Re: LP HELP!!!!! in reply to mike's600, 07-18-2005 15:50:43
Mike
I was in 1st gear in the 7500 lbs class sounded like the govner never opened up.I made sure that it was in first gear because there real strict about that.
thanks
Dave
mike's600
07-19-2005 15:21:02
 Re: LP HELP!!!!! in reply to 900 DAVE, 07-19-2005 04:36:34
Check the fuel filter,it's near the lp tank below the valves.
900 Dave
07-20-2005 04:43:24
 Re: LP HELP!!!!! in reply to mike's600, 07-19-2005 15:21:02
I took it all apart and cleaned it out there was no filter in it so I didn't put one in it could that be the problem.It has good rpm without a load could it be the govner.
thanks
Dave
rgorange
07-18-2005 14:19:42
Fellow I worked for years ago had an LP tractor. We ran it with both open if we were not pulling too hard (a bit more economical I think). We always ran "liquid only" when we were doing heavy pulling.
Engineer20
07-18-2005 13:29:50
My Case LA manual says to run it on liquid.
Goldie
07-18-2005 12:48:32
I dont have an lp but my friend has a lot of them and I think he said you start them on vapor then open the liquid once there warm and close the vapor valve. Sounds good to me.
jal-SD
07-18-2005 06:12:10
Dad always opened both valves on his SM-LPG when using it in the fields back in the '60's & '70's. Don't know if that was correct, but the old girl always pulled really well when doing field work. Wish I would have bought it at the sale when he quit farming. It was a factory LPG, which is not a real common tractor. Oh, well, didn't know then what I know now, and I didn't have old iron disease in my blood then either. (My $0.02 worth. jal-SD)
