dctom...New to Case
Stan(PA)
07-17-2005 17:11:44
dctom, I"m usually not on the Case Forum, but I"m looking at an SC and have questions.
Serial # is 5319183 SC, which is 1949, correct?
It has hand clutch. The grille is sheetmetal instead of cast iron. Is this correct for the year? Runs and starts great, holds 20-22 PSI oil pressure at idle. Gears sound good, but PTO has a whine when engaged. Paint is excellent (restored 4-5 years ago). Questions:
1) Is an offer of $1700 too high?
2) Shift pattern is not like my other tractors (Ford, Massey, Allis, Farmall) It has to be pushed up or down, and then left or right. Is this normal?
3) there is a lever for hydraulics? It goes to what looks similar to a JD B rear rockshaft. Is this for hydraulic lift? (there are no arms on it)
4) It has adjustable wide front. Is this correct for the serial#?
5) I"m really curious about the sheetmetal grille.
Sorry for all the questions, but, after reading the posts on here, it seems you are the guy to ask! Any info you can give me is greatly appreciated. Thanks, Stan.
dctom
07-18-2005 11:26:52
 Re: dctom...New to Case in reply to Stan(PA), 07-17-2005 17:11:44
STAN, 5319183 SC-3 was built may 2 1949 and shipped to j i case company wooster ohio may 3 1949, hand clutch right side is original all sc had that, sheet metal grill is right, oil pressure is right, pto no prob, normal. shift pattern like woman up down is nutral good stuff off to the sides, all sc and dc have that, adjustable axle must have been added by dealer or farmer wasnt built with that but is ok. sounds like you have a real good tractor there HP should be about 32 take two plows anywhere dctom
a little whine
07-18-2005 05:39:41
A little whine in the PTO and 4th gear is normal for an SC. They built some SCs with a hydraulic lift bail instead of the earlier mechanical lift prior to the Eagle Claw (Case 3 point) found on late SCs. Your tractor is probably missing the lift bail. Todd Hamilton
Brian in Ohio
07-17-2005 19:15:21
All of the SCs had a sheet metal grill. THey never had a cast iron grill. And if memory serves me, neutral on the level slides up and down, and it shifts into gear left and right, so that is normal. 1949 is correct for the year.
I'll let DCTom answer the rest of your questions...
Stan(PA)
07-17-2005 19:54:35
 Re: dctom...New to Case in reply to Brian in Ohio, 07-17-2005 19:15:21
Brian, thanks for the info! I really appreciate the help, as I am clueless about Case tractors. I addressed it to dctom because I had seen he had access to build sheets. Your info helps alot. Thanks again...Stan
