sand blasting
ky ted
07-17-2005 16:38:31
just bought a sand blaster today it does a good job but the sand i bought was 20.00 for a 50 lb. bag, and it does not go to far. does any one know of a place to get it cheaper. thanks ted
Dennis/Ohio
07-19-2005 18:55:52
 Re: sand blasting in reply to ky ted, 07-17-2005 16:38:31
I'll be buying sand in the near future. I can't tell you right now but the best way is bulk at around 8 ton minimum for $150. Get a dump truck load & divide it with your buddies.
Fresh air respirator only!!!!!
Best wishes, Dennis..... ....
Doug Boll
07-18-2005 12:51:08
Use a respirator, silica sand dust is hazardous! I have a large Westinghouse compressor, It had a 25hp 3phase motor on it, I had no way to run it so I put a jackshaft from a Habco corn drier on it and run it with my sc, dc, 830ect pto! My dad is retired and works at a casino part time he gets ash tray sand, which I understand is foundry sand. Just have to sift out the cig. butts through screen door screen, it stretches my silica sand! $6.00/100# about right
Gene Dotson
07-18-2005 00:41:00
I have the best service with white silica #60 grit. It is also available at concrete suppliers at around $6.00 per 100 pound bag. When I am on a big project I buy the sand in bulk. The last bulk sand I bought was $28.00 a ton. When storing sand it must be stored in a dry location to prevent accumulating moisture. Wet sand will not flow in our small blasters... Gene
Jim Yadon
07-17-2005 18:32:24
There are different types of blasting sands. We use a silicate sand made for sand blasting and we usually buy ten or more bags at a time. It runs us around $6.00 per bag. These are 80 or 90lbs bags. Can't remember. The only thing I remember is they are very heavy to lift chest high. Local lumber yard is where we buy it from.
