Case SC
Stan(PA)
07-17-2005 09:51:57
Off the wall question, but.... How high is the exhaust stack on the SC? What is the head height with an operator in the seat?
I"m thinking about getting an SC, and the barn is a bit full right now. My garage door height is around 6 1/2 feet tall. I can duck down some, but the exhaust won"t! Thanks..... Stan
it can fit
07-18-2005 05:35:02
 Re: Case SC in reply to Stan(PA), 07-17-2005 09:51:57
My SC has a tractor supply muffler on it that is a little more short than the original stack. It clears my garage door by about 2" but one needs to duck when the old engine lets go of a hot piece of carbon!:^) Todd Hamilton
Ernst Maass
07-20-2005 05:09:20
 Re: Case SC in reply to it can fit, 07-18-2005 05:35:02
You can shim out an H-farmall muffler to work. my Dad discovered that the Farmall muffler would fit back in the 40's. Due to the was effort he couldn't get one for an SC
Randy1685
07-18-2005 04:18:14
third party image
Here is an orginal ad that might help you on my web site.
toomany cases
07-17-2005 20:18:48
Stan, we used to store our 42 SC in a small shed(old chicken coop). It was just high enough for the steering wheel to clear. Pulled the muffler off and put it back on each time it went into shed. Dad insisted that it be parked inside every night,it was new then. Clamp was just loose enough to lift it off at end of day. We used that SC for 4 years that way.
John H-WI
07-17-2005 17:30:50
6 1/2 feet won't cut it cause the muffler situcks up at least 2 feet. Best bet would be the get a locking clamp that you can loosen and take the muffler off if you intend on storing it there.
Stan(PA)
07-17-2005 19:56:48
 Re: Case SC in reply to John H-WI, 07-17-2005 17:30:50
Thanks John, I appreciate the info....Stan
