Jim Nelson-steering wheel
jim handke
07-15-2005 20:28:31
Jim, I just pulled the steering wheel on my 448. After prying the black cap off the wheel, I drilled a 1/2" down the center until I hit the steering shaft. Then I could use a 3 jawed gear puller to yank it off. You have to use a 1/4" nut in the hole to keep the puller from bottoming out in the steering wheel. When you can"t pull the wheel up any more, remove the puller and add a second nut. Bu adding shims like that, it will finally come off. It"s not a pretty job, but that was the only way I could see to get the job done.
