Monroe 3 point on VAI
jdman(MO)
07-13-2005 16:28:21
Anyone ever seen a monroe hydraulic lift on a Case VAI? Friend bought one, uses the torque tube, and regular front pump. Has a unique feature, down pressure. Seat sets on top of the cylinder. Looks like the whole thing including the seat with shock absorber and spring and the housing all came as a kit. Arms are standard cat 1. Russ
mj
07-17-2005 22:59:50
 Re: Monroe 3 point on VAI in reply to jdman(MO), 07-13-2005 16:28:21
third party image
Here's one on a VAO that's similar but uses mostly pieces from one of the add-on kits from CASE.
1031D
07-14-2005 16:14:31
Well jdman, that 3-point setup is really made for an old Jeep. I had one 3-point setup that I sold to a Jeep guy a few years back, and I got another in the shed for the same purpose as yours. They can still be found, but are a bit pricey at $350-500. Check Jeep shows to find them.
jdman(MO)
07-14-2005 17:05:45
 Re: Monroe 3 point on VAI in reply to 1031D, 07-14-2005 16:14:31
You are right it is an accessory for a cj jeep.Found a picture on the web with one mounted on a CJ3. Russ
Arthur
07-14-2005 03:38:21
I ain't ever seen one, but that doesn't mean anything...I don't get out much....Got any pictures you can post?
jdman(MO)
07-14-2005 08:01:00
 Re: Monroe 3 point on VAI in reply to Arthur, 07-14-2005 03:38:21
Picture added in the tractor photos section. S/N indicates it is a 1944. Russ
Arthur
07-14-2005 10:50:46
 Re: Monroe 3 point on VAI in reply to jdman(MO), 07-14-2005 08:01:00
Haven't seen anything like that....I wonder if there still available, as I have a 47 VAI also...
