Case 1370 cracked exhaust manifold
Alan Deglmann
07-12-2005 18:53:03
I have a crack in the center, Y shaped exhaust manifold. This is really more of a nuisance then a problem as it soots up the side of the tractor but does not seem to hurt its performance. How difficult is it to replace this portion of the manifold? The last time any of the bolts were touched was at the factory so I wondering if anyone has ever replaced this part of the manifold and having done so would ever again attempt it?
Tom (Ks)
07-12-2005 19:14:31
 Re: Case 1370 cracked exhaust manifold in reply to Alan Deglmann, 07-12-2005 18:53:03
Been there, done that. Be ready to twist off a lot of manifold studs. If you are carefull, you can cut off the nuts with a sharp chisel or a die grinder. Sometimes the new manifolds will not fit in the old ones because of the heat over time. You may have to grind down the old manifolds to slip in or replace them too.
