Cannot Remove Nylon Bypass Filter Screw on 990
Harvey in Louis
07-12-2005 11:48:58
I let my David Brown 990 set up for about a year. When I fired it back up, the lift would not work right. I came to this site and bought the recommended manual (which is quite good). I then replaced the large transmission/hydraulic filter and fluid. The lift still does not work right. In essence, it raises at high idle and lowers at low idle--regardless of the lift lever position. But when I push in the clutch, it also lowers. When it raises, there is no power there. I can stand on the lift and it goes down. I get off and it goes back up.
Anyway, I feel like the nylon bypass filter is probably the problem. But I do not have what it takes to get that thing out of there. I am using the biggest screw driver I have, but that screw is going nowhere. Now, it is stripping out. I see where the new hydraulic fluid is seeping around the edge of the O-ring beneath this screw. I know it is the new hydraulic fluid, because it looks good. That which I replaced was milky. Because the oil is seeping out, it makes me think there is a good bit of oil pressure there.
Can anyone please tell me a trick to getting this screw out? Or, if you think the problem may be elsewhere please advise. Thank you very sincerely. Harvey in Louisiana
ritchie leslie
07-19-2005 08:44:10
 Re: Cannot Remove Nylon Bypass Filter Screw on 990 in reply to Harvey in Louisiana, 07-12-2005 11:48:58
Suggest you try [email protected] (elmer landman)
I haven't had to tackle that job on my 990..... .
