rebabbitting?
mshultz
07-11-2005 17:47:39
If you need to have rods of a C rebabbitted, what it the potential cost of this? Any places you'd recommend?
Can you just order bearing inserts for the mains, or is there something special about them as well.
Thanks!
Walt Davies
07-12-2005 22:07:16
 Re: rebabbitting? in reply to mshultz, 07-11-2005 17:47:39
The other day we need to rebabbit the main bearing on our IHC 46 baler. We used a small cast iron frying pan a torch to heat it and the used babbit from the old rods. Put it up against the rod with some wire shims to to set the depth and then a small pry bar to set the side by side. heated everything pretty good then poored the new babbit in from the high side. We trimmed it down with a horse shoe file and viola she worked great.. You can use an old crank to get the center or make something that will fit to order. It really not all that hard to do. Just takes alittle patence and steady hand. If its to bog then cut it back to fit. Don't forget to cut the grease Uh! oil reliefs in the center.
Walt
Of course you might just ned to remove some shims to make it fit correctly.
Glenn/Mn
07-11-2005 17:57:55
Which state are you in ?
mshultz
07-12-2005 05:43:59
 Re: rebabbitting? in reply to Glenn/Mn, 07-11-2005 17:57:55
PA
Not sure if I need it done yet - need to tear out another crank and see if it checks okay. Just curious.
Thanks
CLIFF S
07-12-2005 17:57:12
 Re: rebabbitting? in reply to mshultz, 07-12-2005 05:43:59
Ask mEL i bet he can help you or atleast get you pointed in the right direction.
