Case Diesel years/serial number
Dug G.
07-11-2005 09:47:34
Acquired a case 830 a little while back, but it is missing the serial number tag off of the side. Is there anywhere else on the tractor it might have a number like some of the older cases? Also, what year range were they made in? I"m failry sure this is a early one, has older clamshell fenders, and rigid eagle arms. Thanks for any help.
Dug
ld5030
07-12-2005 07:03:30
 Re: Case Diesel years/serial number in reply to Dug G., 07-11-2005 09:47:34
Dug,
I have an older 830 that from the ser.# is a "62 and when I was working on the pto and hyd. pump noticed what I believe to be a casting date on the rear housing. On mine it is located about 6 inches below the pto shaft at the 7 o"clock position just above the casting # for the housing. Mine has 9 11 61. Might help you narrow it down. Jim
Nedd
07-11-2005 10:42:33
Not sure if there is another place for serial number, I know there should be a tag by the fuel pump that will say 301 on it. If you're 830 has a single stick shift with hi-low it 59-60, double stick shifts 60-63, and if the air cleaner is in front of the radiator(hi-profile)it's a 1963 (made one year)64 they went to the comfort king. Others might have more info for you.
jgarner
07-12-2005 05:57:53
 Re: Case Diesel years/serial number in reply to Nedd, 07-11-2005 10:42:33
What do you mean by double stick? Are you talking about the dual range models? Ours had 2 sticks, one for 4 speed transmission and one for "Hi/Lo" range. How does this differ with what you described for single stick with Hi/Lo. The aircleaner was in front of the radiator too. I had no idea what year it was, Dad bought it used in 1966. Great tractor!!
Nedd
07-12-2005 08:55:47
 Re: Case Diesel years/serial number in reply to jgarner, 07-12-2005 05:57:53
Single stick shifter does hi/low plus 4 gear selection with one shifter vs. two. Has a big knob showing selection. These early models also had a different block, crank and oil pump for for diesels(not sure about gas)
jgarner
07-12-2005 13:21:10
 Re: Case Diesel years/serial number in reply to Nedd, 07-12-2005 08:55:47
Guess we had a 63!
