No good on VAC rear differential bushings
Firemanjohn
07-11-2005 09:20:41
I tried the crossed over number to get my differential bushings, but with no luck. Binkley Hurst, who I have had good luck with says no longer available. I am pretty good with salvage yards, but theses are not that type of part obviously. Any ideas on either getting them by measurements or finding NOS?
Joe (Wa)
07-11-2005 20:15:51
 Re: No good on VAC rear differential bushings in reply to Firemanjohn, 07-11-2005 09:20:41
John, I have the cross-ref nr A30528 for VT3765 in the 1968 & 1989 Case part nr cross-ref manuals. I think that A30528 is correct but may have been changed after 1989 or the part has been discontinued w/o replacement.
Go to the link below and search A30528. They list 1 in inv. I would have the parts guy call them to confirm it is the correct bushing you need and find out if they have a source for additional bushings.
If nothing else, if it is the correct bushing, you would have a new sample to target fabrication.
I feel your pain, I am searching for a 2 stud steering lever for an early round nose 300, can't get much more obsolete than that for a modern tractor.
Good luck, Joe
