case cc year?
jaydee
07-10-2005 21:01:05
I have a Case CC with serial #347327, and there is casting # on block that says 8-25-36. Any help would be apreciated on dating this tractor.
L.C.Grey
07-11-2005 19:21:30
 Re: case cc year? in reply to jaydee, 07-10-2005 21:01:05
That sounds like a casting date code from the block. They have them cast in a raised rectangle left side of the block behind the intake manifold.
Its possible someone could have replaced the engine in the past. Check the serial numer stamped in the block to see if it matches the tag. The C's engine serial number is stamped on a raised pad on the right rear corner of the block at the parting line of the head and block.
James Herrman
07-10-2005 22:07:13
I also have a Case CC. My serial # is 327412. When there are 6 digits in the serial #, you combine the first and the fourth and substract 3. In my case when I combine the 3 and the 4 and substract 3 it makes the year 1931. In you case, when you combine the first and the fourth, being 3 and 3 and then substract 3, the year should be 1930. Sounds confusing, but that is what I have always been told.
For years, I always thought ours was a 1936, but have since found out different. Hope this helps. Jim in ILL.
