dc brake seal
Jerry Thomas
07-10-2005 16:39:57
Have a 53 Dc with the left brake leaking oil tore it apart and double sealed it however shaft has rust piting and seal wear gruve so it didn.t hold. Some tractors you can get a thin sleave that slips on the shaftand is glued on .Has any body tied this and if so where can You get one ?
Mathias NY
07-10-2005 18:03:44
 Re: dc brake seal in reply to Jerry Thomas, 07-10-2005 16:39:57
I haven"t been into the brake seals on a DC. However, I have found that moving the seal in or out of the housing can move the sealing lip into a new position and away from the grove.
CR (Chicago Rawhide) also makes a product called a Speedi-Sleeve, these press into place. I have never worked with them myself, but I have heard good things about them. I don"t know the price of them either, but it has to be more reasonable than removing and regrinding the shaft.
C. Amick
07-10-2005 19:34:07
 Re: dc brake seal in reply to Mathias NY, 07-10-2005 18:03:44
I used one of those sleeves on the front main seal on a Farmall Super C. It was a press fit and wasn't glude.
