VAO valves
holcombwa
07-10-2005 15:03:52
Any VA guys know how long it takes to do a quicky valve polish/lap/grind on a VAO head? Weatherman says we can't make hay for couple days yet and number three cylinder is way weak (about 25% compression of other three). Tractor doesn't smoke, and oil in cylinder doesn't appreciably raise compression so..... Can head be pulled, valves lapped, and everything reassembled in a day or so? (Can get a head gasket set at old tractor shop 50 miles away tommorrow if I decide to do it.) Is it worth attempting, or should I try & sneak by making our hay (only about 600 bales) with it this year and save the project for next winter? Stan
Jerry W
07-11-2005 06:25:44
 Re: VAO valves in reply to holcombwa, 07-10-2005 15:03:52
The VAC is real easy to pull the head on but like the previous post states - its' those little "surprises" that always kill the best laid plans.
If everything went well I would be real disappointed with myself if I could not get it done in an eight hour day.
Jerry
C. Amick
07-10-2005 19:30:36
The problem is that you usually run into something when you take it apart that you didn't count on.
