Case 580 CK information. I need the help of a trac
dj112
07-10-2005 09:59:00
I am wanting to purchase a Case 580 CK in the area but I need to get it started due sitting for a long time. On the hood it reads "Case 580 Constuction King" under several layers of paint. The tractor is a diesel and I want to get a manual for it but there are manuals for 580,580B,580C,etc. Since there are several layers of paint and I can't find any #'s to go by yet, does anyone know how to tell for sure which model I'm dealing with? Would it have a "B" or "C" designation on the hood unless it was just a 580 Constuction King? Any help will be appeciated. Thank You.
Roger (Mi)
07-10-2005 20:45:46
 Re: Case 580 CK , 580B, 580C identification in reply to dj112, 07-10-2005 09:59:00
The 530's & 580's are basically farm tractors and have rounded hoods. The 580B's & 580C's have square angles from top to the sides of their hoods. The 580B motors are fastened directly to the torque tube and transmission. The 580C's have torque converters connected to their motors and use open driveshafts to drive their transmissions.
maxandgert
07-10-2005 17:37:49
 Re: Case 580 CK information. I need the help of a in reply to dj112, 07-10-2005 09:59:00
If their isn't a B or C etc. on the tractor it is probably just a plain CK. The Ck and the B are very similar. If you can find a serial number anywhere it would help a lot. The serial number should be on the sheet metal, I think it is on the right side near the steering wheel. The number on the block would be for the motor.
