case 530 construction king
Rejean Cossette
07-10-2005 06:04:00
I want buy this tractor but this tractor is broken,he can not forward and reverse. What is the probleme.The oil level in the transmissionis ok,it is probably a small gear in the transmission is broken. It is possible.It is abig job to remplace it.How much for this piece.
Thank you in advance for your response
PS: EXCUSE MY ENGLISH I AM A FRENSH CANADIAN
Phil (NJ,AZ,Sask)
07-11-2005 02:20:38
 Re: case 530 construction king in reply to Rejean Cossette, 07-10-2005 06:04:00
Rejean, The 530 Clutch is Hydraulic and if you don't have pressure the tractor will not MOVE. (I have to run my tractor for a few minutes before it will move). The Pump is inside but the Filter is in front of the Rad(metal housing) the oil is then feed to the Clutch control Spools (tractor left).
The pressure gauge on the Left side of Instrument Panel measures the clutch pressure.
(105 -120 psi)
The Fluid level has a DIP stick on the Right Side, Just below the FEL(Front End Loader) Control PNL (kinda hidden). You add Fluid through the BELL housing (1/4" Allen head plug) just behind the starter.
Hope This Helps,
Les
07-10-2005 16:20:22
Rejean, I'm not the guy to answer your question but I'm happy to see you coming here to post it. And don't worry about your English. Your post is much easier to read than a lot of people who speak only English since birth. ";^)
Vous etes au Quebec? Je suis au New Hampshire. I can be in Quebec (Chartierville or Rock Island) in about an hour and a half.
J'ais un ami de tracteur qui habite au pres de Lac Megantic. Il a un tracteur Renault N70.
