52 Case SC Rear Main Oil Seal
shorebilly
07-09-2005 06:35:53
Howdy Folks, I would like to know if the Engine Rear Oil Seal is replacable WITHOUT separating the engine from the transmission?
Thanx
C. Amick
07-09-2005 18:17:34
 Re: 52 Case SC Rear Main Oil Seal in reply to shorebilly, 07-09-2005 06:35:53
There should be a gasket between the engine flange and the bell housing flange and also a gasket on the starter.
oldrusty
07-09-2005 06:52:46
There is no rear main seal in a SC. The clutch housing runs about one quart of engine oil. When you change the engine oil you need to drain the clutch housing and then add one extra quart in the engine. It will go to the clutch housing when the tractor is started.
