Looking at a David Brown 1200
andymc
07-07-2005 17:31:52
Wandering if the David Brown 1200 is a good tractor? Is there anything to look for? How hard are parts to come by? The tractor needs a hood and nose, some leaks, smokes a little, needs tires, clutch and tranny ok (not a selectomatic), what is it worth? Thanks for all your help.
Tim B in WV
07-08-2005 16:46:42
 Re: Looking at a David Brown 1200 in reply to andymc, 07-07-2005 17:31:52
Hey Andymc, My Dad had a 1200 DB that went up in a barn fire,and it was the best dang tractor I've ever seen.Period.The hydraulics were a bit iffy at times thanks to the way It "floats"....draft control. The engine never failed to start,the only seriour thing we had to do to it was a new clutch and they can be swapped w/o breaking the tractor in half. It was easy on fuel too,for a 65hp tractor.
0ld farmer
07-08-2005 14:25:42
sheet metal may be hard to find. a few tractor junkyards have David Browns. Case dealers handle some parts. $2000 to 6000 depending on your location and condition. tires could cost up to $1000 or more. will the PTO engage? PTO clutchs can be expensive.
