case0matic
p lloyd
07-06-2005 18:47:57
My case 400 case-o-matic quit pulling while mowing. Trans oil is full. Anyone have any idea what the poblem is. maybe a stuck valve?
Roger (Mi)
07-07-2005 20:29:25
 Re: Check filter in reply to p lloyd, 07-06-2005 18:47:57
The filter is in front behind the grill. The filter can be cleaned with solvents then blown dry with air. If the filter is cleaned and it still doesn"t work, check pressures. If no pressure, then you"ll have to pull the cover on top of the torque tube to check the relief valve and the Case-O-Matic pump. Good luck.
