vac-14 fan belt size
houtz
07-06-2005 14:19:16
My fan belt on my vac-14 just gave up the goast.I cannot find the size required to replace anywhere on this site or in my many manuals.Can anyone please tell me what size to buy.Thanks
Wayne J.
07-07-2005 07:58:20
 Re: vac-14 fan belt size in reply to houtz, 07-06-2005 14:19:16
I can give you a sise but no part # The sise is 7/8 X 45-7/8 with gen. and 3/4 X 40-3/8 without gen. Wayne J.
houtz
07-07-2005 19:31:46
 Re: vac-14 fan belt size in reply to Wayne J., 07-07-2005 07:58:20
Thanks Alot Wayne.I must have a bast--d pully on my gen. because it will not take a 7/8 " belt,also I cannot get a 7/8 " belt between the front casting and the bottom pully.I was in a hurry to use the tractor to move some dirt so I settled on a 45"X1/2".Its a little loose but everything works.Somthing else is going on with it,just started,It will start right up,run fine for 3-5 min. then will cut out just like its running out of gas.Wait a min.or two restart strong,then cut out again.Any thoughts about this ??? Any help will be greatly welcolmed,Thanks Dave
Wayne J.
07-08-2005 09:21:13
 Re: vac-14 fan belt size in reply to houtz, 07-07-2005 19:31:46
Take the fuel line of carb see if gas runs out in a steady stream. if not blow compresd air back into gas tank with gas cap removed.check flow and if flow is not ok remove sediment bowl and pickup tube from tank. drain tank clean pickup tube and bowl flush tank and resamble. add fuel and check flow. atach fuel to carb.start and run check for leaks. if it quits you may have a mag/dist. problem. Remove spark plug wire at a plug. crank engine switch on check for spark.if no spark you have a mag/dist. problem. try this good luck Wayne J.
F-I-T
07-08-2005 08:58:53
You might want to check the top of the sediment bowl for a fine mesh screen, or a screen inside the carburetor inlet elbow. Either way, open the carburetor drain and let it run into a can for at least 30 seconds. If it can't provide a good pencil sized stream for that long, suspect an occlusion in the fuel to carburetor supply. Check that the fuel cap vent is open, too.
Frank
