Case backhoe clutch problem
Hoss W
07-06-2005 03:16:13
A buddy of mine is using a case bachoe, he says it it a model 32, but I believe that is the backhoe number. The serial # is 4083538. Anyhow, he says it works just fine if he holds the clutch pedal up with his foot. If he pushes in the clutch, it shifts just fine, he just has to pull the pedal up and hold it to engage the clutch. So I am wondering, is there some type of spring that could have broken? I haven't seen it yet, but he says there is a "little box" that the pedal goes into. I will be able to tell more once I see it,just wondered if anyone ever ran across this before.
Thanks, Hoss
Dennis/Ohio
07-06-2005 19:18:33
 Re: Case backhoe clutch problem in reply to Hoss W, 07-06-2005 03:16:13
I"m glad Phil helped with the C-O-M clutch spring. I"m only familiar with the dry clutch. What I can add is the #32 hoe was on a 530CK as you suspected.
Best wishes, Dennis..... .
Hoss W
07-06-2005 20:09:27
 Re: Case backhoe clutch problem in reply to Dennis/Ohio, 07-06-2005 19:18:33
Thanks to both of you! I will get a look at it this weekend, at least I won't be flying blind!
Phil (NJ,AZ,Sask)
07-06-2005 13:05:13
That sounds like a Case-o-Matic Control Valve. The Pedal is connected to the Spools... Yes there is a spring, on Tractor Right of the Pedal Shaft, and that returns the pedal.
Hope this Helps,
