VAO oils
holcombwa
07-05-2005 16:50:17
Ok, I'm confused. The "operator's manual" that came with our 1949 VAO says under torque tube, "Temperatures above 60 degrees F. use SAE No. 20 engine oil. Temperatures between 32 and 60 use SAE 10 engine oil. For temperatures below 32 use SAE No.5-W engine oil."
Our "Dealer's Service Manual" for the VA series tractors and engines says for the torque tube, "in coninuous cold weather a good grade of SAE 90 oil should be used."
Last time I drained & refilled torque tube with 20wt. engine oil. Local hardware still carried. What does everyone use in their VA series tractor torque tube and if 20 weight, where do you find it? Thanks in advance.
Stan
F-I-T
07-05-2005 18:03:20
 Re: VAO oils in reply to holcombwa, 07-05-2005 16:50:17
HC:
I think the cinfusion comes from how your tractor is equipped. If it is a ;49 and it's equipped with the Eagle hitch that has the pump on the right front corner of the engine block (live hydraulics), then the torque tube is used as the reservoir for that pump, so it will take 20wt. In Florida here, that's what I use year 'round.
If you do not have the live pump, then those gears on the torque tube are lubed with gear oil, so the recommendation for 90 wt is given.
You just have two different books with two slightly different time frames.
I hope this is accurate. It's close enough to give you the general idea.
Frank
holcombwa
07-07-2005 05:19:21
 Re: VAO oils in reply to F-I-T, 07-05-2005 18:03:20
Makes sense. Appreciate the response. Where can a person find straight 20 wt. gasoline engine oil anymore? Our NAPA says they can't get it and the local hardware (used to stock it in 2 gallon cans all the time) says their source doesn't have it anymore either. Any ideas?
Stan
F-I-T
07-07-2005 05:42:40
 Re: VAO oils in reply to holcombwa, 07-07-2005 05:19:21
I buy it at my local Tractor Supply Store all the time. I woul dthink a quality hydraulic fluid like a #303 equivalent should also work. The anti-foam quality of that is desirable. It might be a bit thin, but I can see no harm.
Frank
