DAVID BROWN
990
Pablo Busanello
10-08-1999 06:41:22
Hello everybody!
I'm Pablo Busanello from Uruguay (South America). A friend of mine recently bought a DAVID BROWN, 990 Selectamatic, 990 A, Serial Number 495448.
He's trying to repair it, and now he's working on the hydraulic gear box.
He need's to know, what special type of FLUID, OIL, etc. is it necessary to put into that gear box; the problem is that he put into what in spanish we call VALVULINA (the same as for cars) and after a while the hydraulic stops working and the appearance of that fluid is like a "boiling milk foam".
Thank you for your kind help!!!!! !!!
Elmer
10-09-1999 05:16:49
 Re: DAVID BROWN - 990 in reply to Pablo Busanello, 10-08-1999 06:41:22
Change the shifter boots if they're torn. Water can leak into the transmission and make the fluid go milky. Change the fluid once a year to keep the system clean.
Shaun In wisconsin
10-08-1999 11:09:44
Sounds like you may have a leak in your radiator.
Wear your oil cooling line goes in or (heat exchanger) check yor antifreeze for oil. Good Luck
