case 350?
TomVAC
07-05-2005 11:50:12
what is a case 350? it has round nose like 300 series. tag says model 351. what is hp etc.
Jim McVay
07-06-2005 04:20:41
 Re: case 350? in reply to TomVAC, 07-05-2005 11:50:12
Yes it is a round nose tractor. 351 is the row crop version with either an adjustable wide front, tricycle front or single front wheel front. 36" rear tire size. 164 cid engine. the only dry sleeve engine Case made. A 350 is a standard tractor with non adjustable front and rear. They became a 500B in 1958 and a 600B with Case-O-Matic. I have one that I restored a use for tractor pulling and ultity work.
John H-WI
07-05-2005 18:22:34
42hp. Not many around, grab it if you can. Very good little tractor!
Glenn/Mn
07-05-2005 13:38:41
350 should have wide front 351 Narrow front
Check the archives
