Powersteering hoses
INcase
01-12-2006 04:58:09
On my 800 the PS pump is on the left side of the engine and the hoses go around the generator and down by the lower rad hose and then to the front. On the 730 the PS pump is on the right side and the hoses go across the motor to the left and then down and follow the same path as the 800. Has anyone tried re-routing these hoses over the radiator by putting a couple of holes in the sheet metal that is above the rad (with protective material) to get those hoses out of the darn way???? Were they like that on the later (front air cleaner & CK) versions?? Thanks
Roger H
01-12-2006 06:48:27
 Re: Powersteering hoses in reply to INcase, 01-12-2006 04:58:09
On Dad's '62 830 the pump is on the upper right side & the hoses go down underneath the radiator to the steering unit.
