VAI Wild Ride
RustyAL
07-04-2005 16:11:57
Finnaly got the VAI running really good. Someone had said that some VAI have a road gear that will take you close to 30MPH. So I could not wait to get it out on the road. She got up to about 15MPH and started rocking back and forth like a canoe on the ocean. The front tires were all over the place. Well, some front end work, steering work and tires may help. Then when I get over the trauma we'll give her another go.
Dave Beiter
07-06-2005 08:45:33
 Re: VAI Wild Ride in reply to RustyAL, 07-04-2005 16:11:57
You haven't lived until you have wound out a Model 42 Silverking.... It will outrun my 530 triple range diesel... (the 530 will run 35 in high range, high gear)
Brian in Ohio
07-05-2005 20:24:38
I have a 38 CC with a 1296 rear end in it. It will do 30 mph. You definately have to be holding on when she gets up to speed...
laipuller45
07-05-2005 19:52:10
our 1952 VAC with 34" tires will do better than 30 mph. the tricycle front end on it smooths out about 25 when you get past 30 the fluid in the tires don't keep up with the wheel speed. it used to have a set of gears for a 28" tractor and would smooth out again past 35. oh btw, there are no flyballs in the govenor.. why??? mystery to us too.. many years ago it was overhauled they were there, the next time they weren't. never to be seen again not even in the oil pan...
Joe (Wa)
07-05-2005 20:42:46
 Re: VAI Wild Ride in reply to laipuller45, 07-05-2005 19:52:10
1952 VAC governor should have flyweights same as VAC14 & 300 series.
Joe
Ken S.
07-05-2005 19:40:55
We used to have a E-3 Coop, that was a fun trip on the road. Front end shook like crazy and the oil slicked brakes left alot to be desired!
Dale(MO)
07-05-2005 06:33:56
I know what you mean. My VC has a pretty fast road gear, probably 20 MPH. With a little slop in the front end, it can keep you from falling asleep!
After a while, your nerves will settle.LOL
Dale(MO)
Les
07-05-2005 05:02:40
I don't think I would ever feel safe driving a tractor that fast. I'd much rather slow down and enjoy the ride.
John H-WI
07-05-2005 15:55:28
 Re: VAI Wild Ride in reply to Les, 07-05-2005 05:02:40
If you ever want something that can scare you try one of the old Coop's. Man those things are way too fast in road gear. Oh, the 300 Case, round nose, with 34" rubber will do over 30 in fourth and high range. Mechanic got a ticket in Menomonie yeas ago going over 30 in a 25 zone. Cop gave him a ticket cause he never had written one on a tractor. Course one of the town drunks had a W9 and he got ticketed for causeing an accident.
