530 construction king backhoe hydralic valves
Wendell Larson
07-03-2005 20:26:49
My backhoe is leeking oil around the control valves on the backhoe. where do I get kits for this and is there any thing else I should know thanks Wendell
Dennis/Ohio
07-06-2005 19:43:53
 Re: 530 construction king backhoe hydralic valves in reply to Wendell Larson, 07-03-2005 20:26:49
The external leaks are seals you can buy from Case inexpensively but if the boom is drifting, it's a metal to metal machined fit. You can replace a section of the control valve if the valve is badly worn or accept the drift. (I accepted the drift).
Best wishes, Dennis..... ....
