Case 841
David Raines
07-03-2005 09:07:02
Hi, my sister has a Case 841 gas and have been helping them geting it running. The hydrolic fluid looks foamy. Could this be caused from water getting into the fluid or is it getting air somewhere? Also there is a cover plate over where the control valves are on the back (just over the pto) which one of the corners is broken. Any body have one of these (it has a case eagle on it). Also any body have an idea of what the tractor is worth?
Thanks Dave
Roger H
07-03-2005 10:21:55
 Re: Case 841 in reply to David Raines, 07-03-2005 09:07:02
As far as the hydraulic oil, it may be the wrong type or water like you thought, it should be either TCH fluid from a Case dealer or the red automatic transmission fluid for cars. You should be able to get a cover plate without much trouble, email Don L at [email protected] to see if he has one, I've got parts from him before. On the value, it's kind of hard to tell without seeing it, the one I have is priceless just because Dad got it new it's also propane.
