Case S
Kevin Brambrink
07-03-2005 08:47:20
I just bought a S model. How do you tell what year it is? Where do I find parst for the mag?
I took the mag apart and the points are dirty and the coil has corrosion and coil tab is almost broke off. When I took the timing plug out to check timing there looks like there is oil in the clutch housing.
Any info would be nice
thanks kevin
John Saeli
07-03-2005 09:41:27
 Re: Case S in reply to Kevin Brambrink, 07-03-2005 08:47:20
Hey Kevin: Parts are hard to come by for the Mag, assuming it's a CASE Mag. That corrosion around the coil doesn't sound good. Clean up the points with some real fine emery cloth. Gap them @ about .015. Clean up all the connections and try it. Some of us on the board here have used Mags for sale. That oil in the clutch housing is a good thing because it is a "Wet" Clutch. Pumped over there from the engine, no rear seal. Be sure to drain the clutch housing everytime you change engine oil.
Kevin brambrink
07-03-2005 15:15:04
 Re: Case S in reply to John Saeli, 07-03-2005 09:41:27
I found a mag for it, The one that was on it was a FM. I asked the guy next door if he had a mag.
He pulled out one from a Allis,had been rebuilt a few years ago. Put it in and fired up the little beauty. All that it cost me was an old belly pump that I had laying around.
The year is a 1941 And it runs out very well. I will have to check the oil as I have drained the cluth housing a few times. The book that I have does not show a wet clutch. Not bad for the $200
that I paid for it.
Thanks for the info
Anymore would be great.
thanks kevin
