830 PTO problem
Kerry Livgren
07-02-2005 07:58:53
I have a '69 Comfort King 830 Diesel. Everything on the tractor works great, including the Case-O-Matic, but when there is any load on the PTO, it begins slowing down and losing power. (The PTO shaft only, not the engine). The PTO engages normally, but at this point it won't even keep a 5' Bush Hog turning when it hits heavy grass.
With no load on it it will spin at normal RPM, but slows or stops until the load is removed.
Any idea what's going on?
Thanks
george md
07-02-2005 16:41:24
 Re: 830 PTO problem in reply to Kerry Livgren, 07-02-2005 07:58:53
Kerry,
Symtoms say you need to adjust the PTO clutch.
It should take quite a few pounds of pull to engage
the pto .
george
Kerry Livgren
07-02-2005 18:24:00
 Re: 830 PTO problem in reply to george md, 07-02-2005 16:41:24
hope that's all it is...thanks
