VAO help
holcobmwa
07-01-2005 06:10:17
Got our VAO fired up (finally) to try and get out and make some hay and..... no clutch. She's been inside the barn all winter. Clutch worked fine last year. Now there's not a hint of one. Tried adjusting the pedal "pull" to no avail. Anyone know if there is a potential adjustment/fix besides splitting her in two to get at the clutch? Any suggestions would be appreciated.
Stan
Jim Yadon
07-01-2005 09:21:54
 Re: VAO help in reply to holcobmwa, 07-01-2005 06:10:17
Hello, On a lot of va series cases they have a small lever on the side of the clutch pedal. If your's does have one it supposed to be there disengage the clutch for long periods of time like for the winter. If your barn is not insulated or there is a lot of moisture during the winter months or spring time. Your clutch linings may be real thin and rust was able to build up to the steel or into the rivets.
My suggestion would be put the tractor in fourth gear and rock it back in forth for a while and it may break the clutch free. Hopefully this will help. Mine did it once and this is all it took to fix the problem. The clutch was grabby for a little while.
holcombwa
07-01-2005 22:41:33
 Re: VAO help in reply to Jim Yadon, 07-01-2005 09:21:54
Jim your awesome! The rocking to and fro in fourth gear did it. I'll readjust the pedal and make hay. Thanks for the help!
Stan
mikefromiowa
07-01-2005 09:18:26
We could use a little more information. Is it stuck engaged, or not.
