Information on David Brown Engine
Bob(VA)
06-30-2005 15:08:46
I have just "inherited" an Oliver 500 that is intact except for the distributor.
The engine is embossed with words "David Brown". The best I can determine, this is really a DB tractor that was imported by Oliver and then painted green.
Can anyone on this forum confirm? Is the DB model 500 the same tractor? What distributor is used on the DB 500?
Thanks in advance.
Bob(VA)
Elmer
07-02-2005 04:40:46
 Re: Information on David Brown Engine in reply to Bob(VA), 06-30-2005 15:08:46
It is actually a David Brown 850, which was designated as the Oliver 500. Not too many of them around. I will have to check, but i may have a distributor here. Is the rest of the tractor in good shape.
Franklin in VA
07-07-2005 15:55:12
 Re: Information on David Brown Engine in reply to Elmer, 07-02-2005 04:40:46
Do you happen to have any specs on the Oliver 500 / DB 850??? Are parts interchangeable with any other model of Oliver or DB????
