David Brown 990
SSS
06-29-2005 21:40:02
I have a DB 990. Trying to vent the fuel system and cannot seem to get a little bit of air out of the top of the glass sediment bowl. Manual says to bleed at the inlet to the first fuel filter but the air stays there at the top of the bowl. My internet is going down at midnight on the 30th, since I am switching providers, so if anyone has some trick I don't know about I would really like to hear about it by the end of day on the 30th. Thanks.
Elmer
06-30-2005 09:04:36
 Re: David Brown 990 in reply to SSS, 06-29-2005 21:40:02
That little bit of air trapped in the top of the glass bowl should not bother anything. It can stay there.
Texas Denny
06-30-2005 07:36:55
When I've had that problem on a gas tractor (haven't experienced on a diesel), I turn on the fuel flow from the tank, slowly loosen the nut that tightens the the glass bowl to the gasket and assembly. As you loosen the the nut, eventually fuel will start to flow out of the the seam between the gasket and the bowl. If the gasket and bowl are sort of stuck together, you may need to move the bowl when the nut is loose. The bubble should be gone as soon as the fuel starts to flow. It is messy but it works. When it happened on the gas, the engine was sort of vapor locked - couldn't get any gas.
