Air Cleaner
Chris Cash
06-29-2005 13:30:59
I have a technical question. I have a 67 990 Selectomatic. I was
unable to find a air cleaner element for a 990. So I bought the entire
air cleaner housing off a 1200 from a guy in Maine. The wrong filter for the 990
that I bought from case fits this 1200. All I need is to fab up a
bracket to mount it. The problem I have is the spot welds in the
little cup inside the oil bath have come loose. I was just going to
tack it back in with a mig welder. But when I stick the tip in, I
can't turn it enough to get the weld under the corner on the cup. Any
suggestions?
~C.C.~
Elmer
06-29-2005 19:03:07
 Re: Air Cleaner in reply to Chris Cash, 06-29-2005 13:30:59
Can you rivet and silicone seal it?
Chris Cash
06-29-2005 20:40:56
 Re: Air Cleaner in reply to Elmer, 06-29-2005 19:03:07
Yeah, someone at work said the same thing. I just was afraid that if I drilled holes in it it might leak.
