VAO coil
holcombwa
06-28-2005 21:41:30
Anyone know how to test the 6 volt coil on a VAO? Tractor ran ok last season and was barned all winter. Now no pop out of the coil wire to the distributor at all. The points spark when opened with a screwdriver, so there is some fire moving about. Just need to see where the stoppage is. Stan
Bret4207
06-30-2005 04:21:36
 Re: VAO coil in reply to holcombwa, 06-28-2005 21:41:30
Change the condenser. I'm finding I hardly get more than 2 years out of any brand condenser any more. Other than that clean all your electrical conections and points. Any other good coil, 6V or 12V, should let you see if it's a bad coil.
holcombwa
07-01-2005 06:14:16
 Re: VAO coil in reply to Bret4207, 06-30-2005 04:21:36
Thanks. The 12 volt coil fired, so went in and changed all the wiring. It was pretty bad (she's a '49 model). That got her going again. Appreciate the response.
Stan
