elmer---im lost
joe e-tx
06-28-2005 19:50:02
elmer my 995 worked fine on sunday,cut hay with my kuhn cutter,finished cutting hyd worked picked up cutter and drove home 3 miles.today 1.5 gallons low on hyd fluid,which i topped off. now have NO 3pt or aux. pressure.no pump noise ,what am i missing. im in TCU,lever moves to height and draft no problem new cultchs in tractor,workin good.what am i missing or what valve needs moved??
thanks joe
Elmer
06-29-2005 19:00:26
 Re: elmer---im lost in reply to joe e-tx, 06-28-2005 19:50:02
I have seen the nut on the pump gear turn loose and the key shear off. You have nothing at all?
joe e-tx
07-01-2005 04:26:45
 Re: elmer---im lost in reply to Elmer, 06-29-2005 19:00:26
sorry had to take mom out of town.have no by pass or fluid flow when looking in right rear cover,i know fluid flows there because thats were i loose my fluid.having hard time getting caps off hold&by pass valves on right hand side under diamond shaped cover.im thinking by pass valve hang.thanks if you read this i know i late getting back
joe
Elmer
07-01-2005 04:41:03
 Re: elmer---im lost in reply to joe e-tx, 07-01-2005 04:26:45
When i come across tight caps like that i use a magnesium punch(Motorcycle Axle)and smack them. They usually come loose then! Use a soft punch.
joe e-tx
07-02-2005 07:28:57
 Re: elmer---im lost in reply to Elmer, 07-01-2005 04:41:03
got caps off no fluid to hold or by pass valves. looks like pump time.its one of those things you have to think out,which i had time to do.will get back of i run in to some thing else
joe
