The gauge has a bourdon tube movement that measures psi the same as your oil pressure gauge. The pressure is generated by a boiling a liquid in the thermo bulb and conveyed by the capillary tube to the bourdon tube (that flat curved tube in your gauge). As the jacket water temp rises, the press increases tending to straighten the bourdon tube (The bourdon tube is half moon shaped so there is more surface exposed to the press on the outer periphery). As the bourdon tube straightens it moves the linkage, rotating the spindle, and thus sweeping the pointer across the gauge face. The fluid used in the thermo bulb will have a temperature/pressure relationship compatible with the range of the gauge bourdon tube. You would have to determine the psi range (0-30, 0-60, 0-100, etc) of the gauge bourdon tube and match a fluid. In the �50�s, R-11 or similar fluid was typical. R-11 is a CFC and is no longer produced in the USA. Your gauge has one of two problems, it has leaked fluid or the movement is binding. Put the thermo bulb in near boiling water and with your thumbnail lift the end of the bourdon tube to sweep the point over to �H�. If the pointer is not held there by gas pressure and drops back near �L� it is low on fluid. You have to have a liquid and vapor in contact to have a true pressure/temperature relationship that will make the gauge function. The thermo bulb holds about 2 oz fluid, it may take years to leak that down to the point the gauge won�t function full range so finding the leak and recharging is time consuming and spendy. Few instrument repair shops will attempt restoration of these gauges, they are simply not economically repairable unless you want to spend so serious $$$. Changing over to a electrical gauge and using your original faceplate is not too hard. I have done that on my 311b & 310 roundnose. Looks original in the cluster panel and works. Here are a couple links if you want to try restoring the mechanical gauge. Link Link Joe
