hydraulics
scotty branham
06-27-2005 15:59:06
Is there any way to get more power out of the hydraulics on my 930 case.
c hess
06-28-2005 16:17:03
 Re: hydraulics in reply to scotty branham, 06-27-2005 15:59:06
Have you checked actual pressure with a gage? iF not up to specifactions you may only need to shim releaf valve on outside of valve body.Pressure should be 1700-1900 psi. If unable to reach that you probably have worn out pump.
DKase
06-28-2005 07:14:45
6 speed or 8 speed? The 8 speed has a MUCH MUCH better hydraulic system and it is much more reasonable to work on. The 6 speed is hard to find good parts for and very expensive! When the pump got weak in my early 830 I replaced the entire tractor with a 830 CK for less money than it would have cost to fix the pump. If you have a 6 speed and just use it for one application I have heard of guys putting 80W90 in the hydraulic system. You would not want to use that machine with a different tractor though. Good Luck DK
