Diesel Fuel and Cleaners
BJS
06-27-2005 10:53:10
Does anyone have an opinion on fuel injection cleaners? Do the cleaners do a good job or just a waste of money? Does the dye in the diesel fuel cause any problems?
Thanks in advance.
Leland
06-29-2005 23:45:44
 Re: Diesel Fuel and Cleaners in reply to BJS, 06-27-2005 10:53:10
Add a couple of gallons of cheap ATF fluid to each tank this will clean every thing out nice and you will notice the differance quick.
Doug Boll
06-29-2005 06:25:05
Sorry if I already submitted this. I saw a power service conditioner that stated "no alcohol" so I don't know if the old advice stands. Considering the cost of diesel components I would consult a diesel shop for their opinion. Had a 400 case that got some crap in it and stuck the injectors, having no atf fluid, I put 2 stroke oil in the fuel, it worked!!
buckmaster 700
06-29-2005 05:11:50
lucus oil products maks a great additive we run exclusivly in our case 700 puller the old tractor was not designed for this new low sulfer fuel this stuff made a big change she smoothed out. also some marvel mystry oil dose good for pump lube and will burn the carbon deposits dont forget if you have and old case diesel with a bosch inline pump you may have one you change oil in every time you do an engine oil change alot of people get an old case and no book on it and dont know it needs to be done
Mark in MA
06-27-2005 17:59:43
Power Service makes a great additive. It raise the cetane, lubes the inj. pump and cleans the injectors. I run it in my dodge ram, makes a huge difference. It is avail. at most parts shops like Autozone. My 2 cents
doug Boll
06-28-2005 11:03:36
 Re: Diesel Fuel and Cleaners in reply to Mark in MA, 06-27-2005 17:59:43
Watch out for alcohol in some conditioners. Alot of guys use Power Service for antigel in winter. The guys at Dakota Diesel told me to stay away from it, unless I liked paying for rebuilding injection pumps!! They said stanadyne and JD (maybe the same product) were good as they are all petroeleum products
