Case ncmt baler
Doug Boll
06-26-2005 18:07:44
I just bought a really nice ncmt baler, I would like to try it out this summer. The knotters appear to be of the Deering design. My dad and grandpa had one in the 60's, dad said they could never make it tie, my neighbor had a 160 with the same problem. The knotters appear to have little wear. Can they be made to work? Does anyone have any dealer service books I could access either photo copies or to buy. I just want to do a load or two and take it to a threshing show, to demo of course. Thanks in advance.
Kim
11-13-2005 09:58:10
 Re: Case ncmt baler in reply to Doug Boll, 06-26-2005 18:07:44
Test
Oldrusty
06-27-2005 18:11:50
NCMT will work good if everything is set up corect as long as someone has not pulled a wagon and warped the chamber. The wagon hitch would pull the camber off to one side with a heavy load and it would not rcover completly
caseman-d
06-27-2005 12:04:59
I do have a operators manual and parts manual fot the NCM baler, lot older than yours. You might try a search on ebay, thats where I found my operators manual.
caseman-d
c hess
06-26-2005 19:53:24
Dad had a ncm an case or someone made a knotter avaible called a Pope. Most of time itworked 80 pecent.not very good! Was painted green. Than dad bought anew case with agenuine case FROM FACTORY knotter(both looked like deering knotters )Worked some better i will leave to your imagination how much better!!!was ncmt baler
Larry Martin
06-27-2005 17:07:02
 Re: Case ncmt baler in reply to c hess, 06-26-2005 19:53:24
The Pope conversion was made right here in Greenfield, IN. All that I saw did't tie but about 75%. My buiddy and I had one and traded it in on a New Idea straight through baler the first year they came out. That wasn't much better as the service department from Coldwater were with us almost all summer as we kept baling the needles.
Superpicker
06-28-2005 21:17:48
 Re: Case ncmt baler in reply to Larry Martin, 06-27-2005 17:07:02
Larry,
Could you e-mail me. I would like to hear about your experiences with that NI beast as I have one.
Thanks
