case 930
nate67
06-26-2005 11:38:35
I am reinstalling a head on my case 930. I have the torque values for head, intake, exhaust manifold, rocker arm assembly but none for the power cell. I don't want to over tighten these. If anybody knows these it sure would be helpful. Seems like these things always happen when you need it the most, haying season and all.
thanks
buckmaster 700
06-29-2005 05:25:24
 Re: case 930 in reply to nate67, 06-26-2005 11:38:35
dont forget to tighten the intake , exhaust,and water manifold before you torque the heads down save a leak in the long run some times the water manifold bolts wont line up if you dont put them on first
Glenn/Mn
06-26-2005 13:52:07
should be the same on all case engines with power cells 100 foot pounds
george md
06-26-2005 18:35:02
 Re: case 930 in reply to Glenn/Mn, 06-26-2005 13:52:07
Glenn,
I hate to be a spoil sport , but my genuine
case service manual says 145 to 150 .
george
colin Sorhus
06-28-2005 13:18:02
 Re: case 930 in reply to george md, 06-26-2005 18:35:02
Does your manual say anything about how to adjust the PTO engage lever? Tks, Colin
c hess
06-29-2005 10:40:05
 Re: case 930 in reply to colin Sorhus, 06-28-2005 13:18:02
8 speed row crop 930--disengage pto- remove hand hole cover on r side- pull out little pin on clutch pack an turn i notch at a time . some turn clockwise others counter c to tighten . you will have to check by checking pull on leaver each time. tighten till you feel snap when disengaging leaver . book says 75-90pounds pull but that is too much comfortable pull from seat is enough. make sure pin goes in when done. you are to have a special tool to do it but you can do it with tools at hand
nate67
06-27-2005 16:18:05
thanks for your help, I'm back in buisness
